2006 Honda Civic odd idle at stop?
Old Feb 22, 2013
Toddb369's Avatar
Toddb369 is an unknown quantity at this point
I have recently purchased a 2006 Honda Civic with 169k. (Automatic)
Ran like a dream for the first month, now when I’m at a stop the car will idle rough (not through the steering wheel) more from the bottom of the car. If I turn the steering wheel the RPM’s will go from about 600 to about 1000 and the rough idle will go away until the RPM’s drop back down to 600.
I have changed the sparkplugs (hoping it would be a fouled plug) yesterday and the car still does it.
My parents mechanic wants to clean the fuel system…
I’m thinking it might be a bad motor mount, but I shift through the gears manually & there is no “thud” or “slamming” of the engine.
Could it be anything other than that?
Old Feb 22, 2013
Re: 2006 Honda Civic odd idle at stop?
I%u2019m thinking it might be a bad motor mount, but I shift through the gears manually & there is no %u201Cthud%u201D or %u201Cslamming%u201D of the engine.
What looks like around 600(ish) on the tach sounds normal and you cannot adjust it.
The normal motor mount failure doesn't cause a thump on accel in this car.
The (engine, front, by the accessory belt) mount collapses and transmits engine vibration throughout the car, mostly at idle and in reverse.
During forward acceleration the vibration goes away.
Check this post: https://www.civicforums.com/forums/1...ml#post4577741
My parents mechanic wants to clean the fuel system%u2026
Doubt it will do anything.
Burn good gas instead: http://www.toptiergas.com/
Old Feb 24, 2013
Toddb369's Avatar
Thank you for that! i will check that out tomorrow.
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
ashleymmackey
Apr 18, 2015 09:48 PM
