Electrical Post information/questions/Issues about Electric parts here.
Rat chewed my wiring, help.
Old Mar 1, 2011
tppiotrowski's Avatar
tppiotrowski is an unknown quantity at this point
Unhappy Rat chewed my wiring, help.
I just returned from a vacation and when I turned on my 2006 Honda Civic Hybrid, the check engine light came on. It was not on before. The fuel cap is on tight.
Upon closer inspection, I found wiring that had been chewed through under the hood. Can somebody tell me what this wiring is for? Alternator? Is it safe to drive to the dealer? Can I replace this part myself and how much would it cost?
The car appears to idle fine.
Thanks,
Ted
Old Mar 1, 2011
lazlong's Avatar
Re: Rat chewed my wiring, help.
You should be fine to drive. The only wires you don't want to touch are the orange ones, they're for the electric drive system. 50,000 volts- can you say Human Torch. lol
Old Mar 2, 2011
BlueEM2's Avatar
Whachya lookin at?
OOooo 50000 volts .... They are sensor wires which explains the check engine light. I'd drive it on to the shop or disconnect the battery and repin the connectors.
Old Mar 2, 2011
CraigW's Avatar
If it is just the 2 wires I would repair it yourself. Easy to match color, splice in a new section of wire if needed. Solder them and heat shrink 1 or 2 layers then tape up.
Old Mar 2, 2011
BlueEM2's Avatar
Whachya lookin at?
^ Agreed.
Old Mar 2, 2011
lazlong's Avatar
^^ x2
trellex
Jun 30, 2015 07:13 PM
Black91civic
Jun 6, 2015 08:15 AM
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
TopFuel
Jan 25, 2002 07:03 PM
