2002 civic si signals hazards not working HELP
Rep Power: 0 2002 civic si signals hazards not working HELP
Ok listen I’m new to this so please don’t use Honda talk
i read other post and tried everything
Not turn signals or hazards or dashboard green blinkers
hazards weren’t plugged in (I plugged them in)
new lights
new flasher
new fuses
(driver side missing socket working on that)
but shouldn’t some lights come on just not the driver side?
new lights
new flasher
new fuses
Re: 2002 civic si signals hazards not working HELP
Got wiring diagram?
Got voltmeter?
Got test light?
Got power?
Got ground?
In the right places, at the right times?
Got voltmeter?
Got test light?
Got power?
Got ground?
Rep Power: 0 Re: 2002 civic si signals hazards not working HELP
Got wiring diagram? Where do i fiind this at???
Got voltmeter? Why do I need this??
Got test light? How do I do this ?
there is 8 turn signals the light bulbs work t
Got power? Yes because all other lights work
Got ground? Where is this? The battery has all the ground connected just fine
In the right places, at the right times? I don’t know
Can you explain what you are saying?
FWIW if the hazard switch is bad (or unplugged), on some cars that will completely prevent the turn signals from working.
Did someone just forget about it? Maybe it was unplugged for a reason?
Which fuse did you replace? Was it blown?
Did you check any other fuses? (the turn signals and hazard lights have more than one fuse)
Dash fuse box fuse #19
Engine compartment fuse box fuse #5
sooooo I just because I was being a brat and trying to save money on the civic si switch 85 bucks at auto zone and since I didn’t know the problem I went to the junk yard and found zero civic si hatchback so I took a switch from a different civic si and plugged it to the car well it literally turns the dashboard lights on without the key ! I joked around saying it was a push to start.. well it does turn the signals on but doesn’t blink and messes with the lights so I order the original switch .. I’m sure the new switch should work be back later if it doesn’t
and yes I change relay flasher fuse 19 checked fuse 5 (under dashboard) and all the fuses under the hood with the tester..
steveneddy
05-19-2015 02:39 PM
Muzyy2813
02-10-2015 11:40 AM
Colombian4Lyf
10-24-2006 10:54 PM
