Help!!! Stereo buzz and no horn!
Old Jan 20, 2010
Rijuken's Avatar
Rijuken is an unknown quantity at this point
well heres the deal.. i just put in a new stereo in my car and made sure all the wiring was tight, had one of my tech buddys help me out too, but now when i drive the speakers seem too buzz at low rpms or shift from 1 to 2... idk why buts its annoying. next is the horn, i puch my button but just the relay clicks.. no sound.. any help????
Old Jan 20, 2010
Re: Help!!! Stereo buzz and no horn!
check the fuses? maybe the deck isnt grounded properly, that will cause noises.
Old Jan 20, 2010
Rijuken's Avatar
thx ill get on that
Old Jan 20, 2010
D940's Avatar
D940 should not be trusted
Always Check Power and Ground....You also might have high resistance somewhere where you mounted your stereo, which could be giving you that buzz.If your tech buddy has a logic probe or a DMM you can use that to test your fuses. Just looking at it isn't going to solve the problem. And just because your relay clicks doesn't mean its working. You could not have power to the fuse box for that relay. Take a DMM and check how much resistance you have on that relay from the 85 and 86 slot, and take a 9v battery and make it click to turn it on.
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
MamaBear2015
Sep 24, 2015 11:34 AM
zeshan7616
Sep 15, 2015 12:24 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
