what amp for foglight
Re: what amp for foglight
no, not unless you put in bigger wires. replacing a fuse with a larger one is just begging to create an electrical fire. fuses are sized based on the wire size. putting a larger fuse in will allow more current to flow through the wire than it can handle. it will get hot and possibly catch fire. fuses are there to protect the system when there's a problem. if the fuse blew, you have a problem. for a fuse to blow, power has to get shorted to ground. it could be a wire or component that is shorting out.
im not sure what size, but it came with a 30 amp fuse. I believe I am using 2 55watt bulbs.
and this is what happened after over a year
i replaced the in cabin harness (with a new fuse holder) with another one that my friend had around and everything works again, but I am also using a 30 amp fuse (smart glow - made in Mexico). But I do not know if this will happen again.
30A fuse, you need 10ga wire. 2-55w bulbs need 9.16A. Call it 10A. 15A tops if the wires are big enough (14ga or bigger). if it came with a 30A fuse, then that's probably why things melted. the fuse needs to be small enough to protect the smallest wire in the whole circuit, not the supply. so even with a 10ga supply (if you had that) if any wire is 14ga or smaller, then you need 15A or 10A, not 30A. does that make sense? I'd put a 10A in there. if it blows right away, you probably have a short somewhere.
can i try a 15 amp ? i have one laying around
so a 30 amp fuse has more chance of catching on fire than a 15 amp fuse? If my wires are more powerful than the 15 amp fuse then it'll just blow?
so what i'd suggest is look at the wire and find out what size it is. there should be writing somewhere on the power and ground wires. once you find that, then you can determine what fuse you need. if a 15A fuse blows with 2-55w halogen bulbs, then you have bigger problems. you have a short to ground somewhere either in a component or wire.
i just checked all wires around and leading into the fuse box cover and there is no writing on any of them...
what exactly is a short to ground?
and if a 15A fuse doesnt blow, i can just use it and assume that the 30A was too much? If I do recall, one of my bulbs did burn out and I drove around with one bulb for quite some time.
short to ground is when a power wire makes contact with bare metal or a ground. since there's no resistance from a component like a light bulb, then excessive amounts of current flow and things get hot and turn bad.....unless a properly sized fuse is there to protect the system. put the 15A in. if it blows, you've got an electrical problem in the wiring somewhere (assuming both lamps are good).
and if the 10A doesnt work and blows?
I'm leaving the fuse box sticking a little out so I can look at it easily if it ever melts again. thanks
2-55w bulbs at 100% efficient need 9.167A. there's resistance in the wires, maybe in your grounds, so normally, you size your fuses or circuit breakers based on 125% of the full current load. so 110w would need 11.46A, so you'd pick a 15A or 12.5A (if you can find one.)
sorry for the off topic, but the same thing happened to my DRL module fuse and holder. its only a 7.5 amp fuse and the wire looks pretty thick, like at least 16 gauge, maybe 14. but the holder and fuse were totally melted. i was barely able to pull the melted fuse out (which still worked actually), and put a new one. the holder was badly damaged but still held the new fuse. i havent checked it recently and im not sure why it would melt like that. its powering the two front turn signals at 42w total.
hard to say on some of these. any corrosion on the terminals will add resistance and thus add heat. or a loose connection can do it too. any connection i make in the engine bay, i put dielectric grease on it to prevent corrosion.
h4ldol
Apr 24, 2017 08:16 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
