Legitimacy of this article
http://www.ehow.com/how_2042670_conn...-lighting.html
Is that a good way to fuse something? Why do you need to attach the negative wire to the negative terminal of the battery? Isn't one of the prongs on a fuse negative, the other positive?
Re: Legitimacy of this article
I don't see why you would need to connect the lights directly to the battery, unless they are using a large amount of power. Connecting the (-) side to anywhere on the frame of the car should give you a decent enough ground. As for the (+) side I would try to locate the headlight fuse or something similar to connect to, instead of a random fuse like the article suggests.
h4ldol
Apr 24, 2017 08:16 PM
powman02
Sep 15, 2015 07:38 PM
tomas6791
Sep 11, 2015 06:47 PM
tomas6791
Aug 22, 2015 12:20 PM
carid
Aug 8, 2015 05:05 PM
