HELP! Viper Alarm Issues
Old Aug 18, 2007
MERC's Avatar
MERC is an unknown quantity at this point
I currently changed the battery in both remotes to my Alarm Sustem
(Viper 850XV). Since then the remotes/ alarm don't work anymore. I already checked the box, and changed all the fuses I saw, what do I do?
Old Aug 20, 2007
electric130's Avatar
Re: HELP! Viper Alarm Issues
did you check the installation manual? it tells you how to learn the remotes.
Old Aug 21, 2007
instalher's Avatar
instalher is an unknown quantity at this point
plug in the bit writter and find out whats going on.... learn the remotes to the alarm and if this still doesnt work pull the alarm down. grab your multimeter, and see if there is ground on the black wire, then check for power on the red wire, with those two aok then email back and i will go from there, we will get this alarm working good buddie!
Old Aug 21, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
^^^ correct. the first thing i would do is check your wiring and check the unit for power and a good ground connection.
civic1316
May 29, 2015 05:13 PM
Laurenhunter7
May 10, 2015 01:09 PM
Linda0818
Apr 23, 2015 11:30 AM
