car shuts off for no reason
Old Jul 28, 2007
wallice's Avatar
wallice is an unknown quantity at this point
car shuts off for no reason, did it yesterday morning while i was driving down the highway, i coasted to an off ramp tried to start the car. it started i reved the motor a couple times and stood back and it shut off again. would not start had it towed to where i work took the distibutor off and checked the wires. i have an msd sci 6300 with msd pro cap and blaster 2 coil. brand new ignition control module. i had no check engine light on at the time. but when i jumped the computer with a paper clip it pulled a bad ignition output signal, what could my problem be. i took it for a ride tonight and it shut off when it restarted it was fine, coming home it bogged down really bad like a dead spot then went again.
Old Jul 28, 2007
endlesssssssss's Avatar
endlesssssssss is on a distinguished road
Re: car shuts off for no reason
have you removed your battery recently? if so, did the problems occur after you removed it?
Old Jul 29, 2007
wallice's Avatar
no battery hasn't been removed for a couple weeks, i had everything tested the battery was good, i replaced my alternator a couple weeks ago.
Old Jul 30, 2007
wallice's Avatar
well, i tried changing my blaster coil with another one, that didn't work. i tried changing my msd box with a 6al that didn't work, i'm thinking i might try the ignition control module again to see if that's it. when i start my car it misses and seems like there's a drop in vaccum what would cause this, i hit the gas a couple times and its fine. but i have a vaccum gauge in the car and it runs around 20psi, volt gauge drops a bit, oil pressure is good, fuel pressure is around 50 cause of skunk2 intake manifold
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Dorval Andre
Apr 20, 2015 05:34 PM
smmahan
Apr 15, 2015 08:17 PM
EXWisdom
Nov 5, 2001 10:24 PM
