Notices
Wheels and Tires Post your wheel and tire related questions here.
New Tires - Stock 04 EX Coupe - Best size for Summer Performance?
Old May 1, 2013
Matt Bachand's Avatar
Matt Bachand is an unknown quantity at this point
Hi guys. I am removing my winter tires, and need to buy a set of summer tires. Don't need all season. Want best MPG / Wear.
Anyhow, I think stock tires are 195/60 r15.
Should I stick with that size, or should I get something a little wider?
Any suggestions/input greatly appreciated! Thanks.
Old May 1, 2013
GolNat's Avatar
Prelude Owner
Re: New Tires - Stock 04 EX Coupe - Best size for Summer Performance?
I would go with the widest tire you could fit on the rim. That would be best for handling. Might not find to many high mileage/mpg in a wide size though.
Old May 3, 2013
Ok, so there are no known rubbing issues?
I only have the stock alloy 15" rims, so I'm sure I can't go too wide, but maybe a little wider than the 195/60r15's that are on there now?
Thanks.
MRB
Old May 3, 2013
GolNat's Avatar
Prelude Owner
No known rubbing issues that I am aware of. I run a 205 on a 16 inch rim. Other people have 215's and there may even be a 225.
Here is a good calculator for calculating the dimensions:
http://www.tacomaworld.com/forum/tirecalc.php
If you went to a 215/55/15 it would keep your rolling diameter approximately the same.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
technosilver
Nov 14, 2001 10:58 AM
