Notices
Wheels and Tires Post your wheel and tire related questions here.
Broke and stuck wheel bearing
Old Apr 28, 2013
hwilson1371's Avatar
hwilson1371 is an unknown quantity at this point
Her we go. I have a bad rear wheel bearing on a 96 honda civic. I removed old hub assembly and the inside Ring of wheel bearing stayed on shaft. How do I remove that ring?????. There's no way to grab it????
Old Apr 28, 2013
Re: Broke and stuck wheel bearing
I use a handheld cutoff wheel tool to make a slice in the race, then hit it with a cold chisel to crack it all the way through (you cannot cut the entire width with the cutoff wheel without harming the spindle). After you crack it with the chisel, it will slide right off.
Random GIS pics:
Or a Dremel, they have cutoff wheels too.
Make the slice in the stuck race, then whack it with the chisel:
Do NOT use cheapo cutoff wheels:
I use 3M discs on my cutoff tools.
Hqly2001
22
Jul 12, 2015 06:44 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
AaronSorenson
Jul 7, 2015 09:40 PM
BootyDo
Jul 7, 2015 06:06 AM
