Notices
Wheels and Tires Post your wheel and tire related questions here.
Best way to paint Rims?
Old Nov 6, 2011
youmadeyou's Avatar
youmadeyou is an unknown quantity at this point
What the best paint and steps too use for painting Aluminum rims?
Old Nov 6, 2011
youmadeyou's Avatar
Re: Best way too paint Rims?
no one really ?
Old Nov 6, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Best way to paint Rims?
Getting it powder coated
Old Nov 6, 2011
02civicsi02's Avatar
Low and slow!
This, when you powder coat stuff that **** stays on. Sand blast them then powder coat them.
Old Nov 6, 2011
MindBomber's Avatar
Live for the Twisties
Powder coating is a minimum of $300 for a set of rims in Vancouver, that's not cheap.
OP, I wrote a long as response, then my wireless crashed, I'm honestly to lazy to write it again. Hit up google, there are a ton of DIYs on painting rims out there.
Old Nov 6, 2011
Kenny the Ricer
He asked an arbitrary question, and I gave him an arbitrary answer
"Best way to paint"
Old Nov 6, 2011
youmadeyou's Avatar
Not looking to powder coat them ... there cheap rims . just need them to look descent of a bit.. they have a chrome finish on them now. Looks like some one tryed to paint one of them white once but I guess they changed there mind and took most of the paint of Im not a big fan of the chrome looks so I would like to paint them..
Old Nov 7, 2011
Kenny the Ricer
Rattle can Dupli color chrome then...
It's kinda of a matte off silver finish rather than chrome.
Otherwise gloss black always works nice
Old Nov 7, 2011
youmadeyou's Avatar
Will i have to prep the rims before spaying them? mean sand them or anything?
Old Nov 7, 2011
MindBomber's Avatar
how to paint over chrome..
Painting over chrome:
Start by washing with soap and water. Then clean the part with a quality wax and grease remover (PPG DX-330, DuPont Prep Sol, etc.).
If the chrome is peeling, cracking, chipping, etc., remove it by grinding (24 or 36 grit) or bring it in and have it de-chromed.
If the chrome is in decent shape (scratches are fine as long as they don't cause peeling, cracking, chipping, etc.), sand the whole part with 80 grit on a dual action sander or an angle grinder. Make sure there are no shiny spots left anywhere or it will peel.
Prime with a self-etching primer. Follow the instructions for your particular brand. They vary in application. If the self-etching primer requires sanding before top-coating, sand it according to the instructions.
If it does not require sanding, after the appropriate tack time, apply a quality primer/surfacer to fill in the 80 grit sanding marks and any other minor imperfections.
If there were any dents or dings to fill in, fill them in after applying the self-etching primer. Body filler will stick to self-etching primer, it will not stick to chrome.
If you sand through the primer at any time while sanding, you need to re-apply it to that area. Clean the part once again, using wax and grease remover (PPG DX-330) and/or final prep (PPG DX-320). I prefer DX-330 before sanding and DX-320 after sanding.
Once you are satisfied with the surface prep, you can topcoat with your favorite color and paint type.
If you are applying a spray can finish, there are some that claim to be one-step but I don't know how well they hold up after time. I have some painted-over-chrome parts out there for well over 10 years without a problem using the above methods, on cars and trucks driven on the street, not trailer queens.
Old Nov 9, 2011
youmadeyou's Avatar
Thats cool thanks . but the rims are not chrome there aluminum . will this work on them as well ?
Old Nov 9, 2011
MindBomber's Avatar
so when you say chrome finish then, are you meaning polished?
Old Nov 9, 2011
youmadeyou's Avatar
Damn, Yea my bad polished aluminum ..
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
carid
Sep 28, 2015 10:13 AM
