Notices
Wheels and Tires Post your wheel and tire related questions here.
lug nut dimensions?
Old Jun 6, 2010
M4n1aC's Avatar
M4n1aC is an unknown quantity at this point
lug nut dimensions?
I bought rims for my civic. I need to buy lug nuts that will actually fit into the lug holes on the rim. I was wondering what thread size I need and also I need to know the depth.
Old Jun 6, 2010
Re: lug nut dimensions?
M12 x 1.5
If you get open ended lug nuts, depth shouldn't matter
Old Jun 7, 2010
speeeedddddfrea's Avatar
speeeedddddfrea is an unknown quantity at this point
m12 X1.5. the lugs should have a tapered bottom.
Old Jun 7, 2010
Yea.. the taper shouldn't matter (seeing as how all lug nuts have the taper) unless you decide to pick up some no-**** mugen rims. the taper on those are at a 45º whereas all others are at 60º. But, if you're gonna front the cash for some no-**** mugen's, then you shouldn't have a problem picking up mugen lug nuts as well
Old Jun 8, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
make sure you do not need tuner lugs as well, which are thinner. still same size 12 x 1.50.
Old Jun 8, 2010
if you have aftermarket rims, you almost guaranteed to need tuner style nuts. do not use the oem nuts.
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
siliconvalley
Sep 15, 2015 09:48 PM
Jrosa
Sep 14, 2015 08:24 PM
