Notices
Wheels and Tires Post your wheel and tire related questions here.
New Wheels! I has ?'s!
Old Apr 29, 2010
dnice78's Avatar
dnice78 is an unknown quantity at this point
Just picked up some new 16x7 Rota Circuit 8's for autoX. I was wondering what size tires you guys would recommend, I want something a little on the meaty side
(tires aren't mine, and sorry for the shity pics, it was late)
Old May 1, 2010
dnice78's Avatar
Re: New Wheels! I has ?'s!
Nobody?
Old May 1, 2010
BlueEM2's Avatar
Whachya lookin at?
Are you going to be using them for strictly autoX? So I guess you don't care about the accuracy of the speedo and that junk.
If your doing daily driving in them use this tire size calculator :
http://www.procivic.com/pages-honda_...ide/index.html
I'd go with: 215/45R16
Old May 1, 2010
TheGreen's Avatar
TheGreen is an unknown quantity at this point
yeah but I think you can also get brake problems if you get tires with a bigger diameter then stock
Old May 1, 2010
BlueEM2's Avatar
Whachya lookin at?
I used a tire calculator to calculate this. So the diameter should stay roughly the same or within spec anyway. I'm not too informed on suspension and rims but I'd assume that it would work!
Old May 2, 2010
TheGreen's Avatar
Yeah the tires you told him to get would be good, but you said if he used it only for autox he could get bigger, but that's where the brakes could **** up.
Old May 2, 2010
BlueEM2's Avatar
Whachya lookin at?
Yeeea.. I never really said go any bigger than those. I think anything else and you might get some rub issues But again, I'm no expert on tires by any means. I just knew where to locate the calculator and picked the meatiest tires on it
Old May 4, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
If you want to play it safe go 205 45 16, that is what is most recommend for 16 inchers.
Old May 8, 2010
dnice78's Avatar
Thanks for the help guys! Rep for all you Also, I plan on going lower in the future, does that mean I'll need even smaller tires?
Old May 8, 2010
dnice78's Avatar
tbohar, I need to spread rep before I can give you more
siliconvalley
Sep 15, 2015 09:48 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
rainman15
Sep 6, 2015 11:10 AM
