Notices
Wheels and Tires Post your wheel and tire related questions here.
Going from 15in caps to 14in rims?
Old Mar 20, 2009
Retell's Avatar
Retell is an unknown quantity at this point
Question Going from 15in caps to 14in rims?
I have a 2005 Civic LX 4 Door. It currently has 15inch stock hub caps. The current tires have ~20% tread left so I am beginning to enter the market for new tires.
One of my friends offered to sell me all 4 of his 14 inch Enkei RPOM rims with new tires for $180.
Naturally this is a pretty great deal, however how will this effect my car? Won't this mess with the speedometer and ABS?
Old Mar 20, 2009
Re: Going from 15in caps to 15in rims?
i remember someone switched to 14s and didnt notice any problems, technically it should be fine if the right size tire is used. odometer problems only result from using a different tire that is not sized properly for the rim. and if i remember, only the EX comes with abs and 15s. the LX comes without abs and with 14s from the factory. if you post a pic of your hubcaps, i can tell you right away what the size is.
Old Mar 20, 2009
Retell's Avatar
I was pretty sure all the '05s had at least 15s. Not my car, but these are the cabs on there:
Old Mar 20, 2009
lordhelmet's Avatar
They changed to 15s on all models in 02 or 03. My 01 LX had 14 inch steelies stock.
Old Mar 20, 2009
ya okay it was 03 i believe. the 02 lx/dx still has 14s. well the easiest way is just look at the tire. it says what the rim size is at the end of the numbers.
Old Mar 20, 2009
Retell's Avatar
Re: Going from 15in caps to 14in rims?
I know for a fact my hubcaps are 15s. I just want to know if going down to 14s will mess up my car. I'm also pretty sure it has ABS. I will double check tonight.
Old Mar 21, 2009
when you first turn the car on, you should see the (!) light on the gauges if you have abs.
Old Jul 28, 2009
ap891's Avatar
ap891 is an unknown quantity at this point
i think my '03 lx coupe has 14" wheels? the tire size on my last tire change said 185/70-14
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
cferry7
Oct 3, 2015 04:33 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
