Notices
Wheels and Tires Post your wheel and tire related questions here.
What (ebay) Drilled Rotors?
Old Aug 19, 2007
carter's Avatar
carter is an unknown quantity at this point
Can some one help me find a proper set of Drilled Rotors that work well and would be reliable this would be my first purchase for the breaks and i was wondernig which ones would fit best. I have a 2004 Honda Civic EX Sedan.
Old Aug 19, 2007
rick1574's Avatar
rick1574 will become famous soon enough
Re: What (ebay) Drilled Rotors?
i've got brembo blank rotors i just installed on my 04 civic vp and they work great. they're not drilled, but my 100mph-60mph distance has dramatically shortened, not to mention my 60-0 stopping distance.
$100 shipped from dezod.com
Old Aug 19, 2007
Alpha 5's Avatar
If you are not going to go with a big brake kit, then you do not want drilled rotors. Our rotors are so small that by drilling them you are just going to hurt their ability to stop the car. Explanation, by drilling or slotting them you are removing the much needed surface area on the already small rotors there by drastically degradating their ability to stop. Also the longer stopping distance and the increased pressure needed to stop the car will cause them to heat up quicker and not last as long.
Old Aug 19, 2007
greeen01civic4d's Avatar
if u still want to go with drilled and slotted rotors, go to summitracing.com, i got em for like 55 a rotor, which aint bad, and i love em, they stop great, its constantly over 100 degrees here, so the heat dissipation helps a lot
right side... http://store.summitracing.com/partde...5&autoview=sku
left side...
Old Aug 19, 2007
Alpha 5's Avatar
Here is a good thread to read before you go out and purchase stuff.
https://www.civicforums.com/forums/4...ed-rotors.html
Old Aug 23, 2007
acchione's Avatar
acchione is on a distinguished road
i've had brembo cross drilled and now the slotted. the drilled ones warped on me prematurely. the slotted seem a lot better, but i also upgraded to some SS brake lines at the same time. i'll be sticking w/ slotted but brembo blanks are always good too. your money, your call.
Old Aug 23, 2007
rick1574's Avatar
f1 cars don't use slotted and cross drilled front rotors and they brake from 200mph down to 60.
Old Aug 23, 2007
Alpha 5's Avatar
Good post, you just regurgitated what someone else said in a diff thread but at least you retained it.
A big +1 for you.
Old Aug 23, 2007
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
sportbrakes.com is where i got mine. i got the cross-drilled and slotted zinc plated. i know the guy so mine were free =D but if you want i can ask to see how much they will cost ya... im sure he can get you a deal, just depends on what you want.
Old Aug 23, 2007
rick1574's Avatar
A big +1 for you.
gotta spread the good word.
thanks!
Old Aug 24, 2007
carter's Avatar
How much could you get me some Rotors and Pads for?.. Im not looking to high end. 2004 HOnda CIvic Ex 4 Door.. So its a 4 Bolt Pattern anyone?
Old Aug 24, 2007
aznprid214's Avatar
did you try the site yet? www.sportbrakes.com
Old Aug 25, 2007
rick1574's Avatar
100 shipped for brembo blanks (both sides)
50 for dezod x rated pads
www.dezod.com <--a great place to buy parts
SammySC
121
Apr 7, 2017 07:43 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
amrhamed
Sep 21, 2015 02:56 PM
zeshan7616
Sep 15, 2015 12:24 PM
