Notices
Wheels and Tires Post your wheel and tire related questions here.
master cylinder?
Old Jul 25, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
master cylinder?
ok so heres whats up. yesterday i took the rotors off got em turned then out em back on nothing more than that. after that ive got like a dead pedal. it stops but its mushy and sometimes the stiff pedal comes back. so i think somehow i got air in the lines. i took it to my mechanic (well i wouldnt call him my mechanic he just does the stuff i cant do dont have time to do or dont have the right tools for) we bleed the brakes still soft.
so heres what we are both thinking its my master cylinder. now heres what im asking are there any upgrades or any advantages to going with say an ep3 master? or should i just get the ex one again. changing isnt gonna be hard just curious if there are any upgrades since i gotta change it.
thanks
Old Jul 25, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: master cylinder?
I've never been made aware of any advantages using the EP3 or even an aftermarket one. I don't think the master cylinder itself would benefit from being a high performance one. I just think that you can get better brake fluid. I would imagine that the hydraulic pressure would be the same, maybe a little bit more on the EP3 one, which I don't think would be a good thing, considering that you still have EX calipers and lines. Someone else might know more details, but I don't think there's a benefit.
Old Jul 25, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I read that they are the same in the drum to disk conversation thread...
Old Jul 26, 2007
Zzyzx's Avatar
Autocross Junky
Tweaking the Master cylinder size is just going to alter how the brake pedal feels. Firmer/higher vs softer/lower, depending if its got a lager or smaller diameter. Braking power will have remained the same, given that its determined by your tires and not your brakes.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
powman02
Sep 15, 2015 07:38 PM
dantheman42
Sep 4, 2015 01:10 PM
