advice on buying a civic (descriptive subject for the thread, as per forum rules)
What's up guys. Looking for a small 4 cylinder to take on trips and save on gas. I've never owned a honda, but the fiance has had an 05 accord with a K24 in it ever since I met her. I've done a bit of work on it in the past. No stranger to wrenching.
Found this near me. He says the timing belt was done at 70k miles. Says there has been a little work done to it. Mainly preventative maintenance. Only thing I really don't like, is that it has headers, intake and full exhaust done to it. Worris me with how people drive it.
Are their any notorious issues to watch out for with these 7th gen civics? Anything to keep an eye out for when I go check it out? Thanks for the heads up!
https://chico.craigslist.org/pts/d/w...848240532.html
Re: Need help on this...
WHY is it for sale? Not what bs they want you to hear, but the real reason?
I'll guess.....something expensive needs done
maybe
Can't pass smog (cat not carb compliant?)
needs a head gasket job (or worse)
trans has noisy input shaft bearings
The exhaust.............I'd expect it's been driven hard (really, what does every kid with a loud exhaust do?)
IMHO I'd rather have your GFs Accord, those tended to be pretty dang reliable as long as they weren't neglected
maybe
maybe
maybe
BUT he was straight up, told me the input shaft bearing made noise...which it does. Every so slightly at an idle while in nuetral. He just switch it out (proven paperwork) and it still has a small noise.
Is this a common issue with these Hondas?
Re: advice on buying a civic (descriptive subject for the thread, as per forum rules)
Fault codes erased just before you arrived? (check readiness monitors for completion)
Suspension needs?
Mysterious electrical gremlins?
How about that head gasket?
I keep thinking of stuff
If it had auto trans that would have been on top of the list too
Head gasket is a common failure on that particular engine but many people don't figure it out in time
That may be normal noise then. Most manual transmissions from any manufacturer are not perfectly silent while shafts and gears are rotating inside it
Suspension needs?
Suspension needs?
Only thing electrical is....the SRS light is illuminated on the cluster. Guy says it's never caused problems. Makes me wonder if one of the airbags are faulty?
Other than that, the rear dome light doesn't work. He says the wiring is fudged. Everything else works great.
No issue with CEL or fault codes. He just had it smogged 3 days ago. Showed me the certificate. And if fault codes were erased recently...CA smog shops have software that sees that and will automatically fail the inspection.
I really do appreciate your feedback, bud. Knowing the head gasket is a issue on these D17 motors...does worry me a bit.
If the SRS light is on, in a collision one or both airbags will not deploy.
Might be as simple as a bad seatbelt sensor, might be as complicated as bad control unit (those suck to pull out).
Using a air compressor and pressurizing each cyclinder to 120psi and looking for air bubbles to appear in the coolant is the only valid test for Honda headgasket.
Reading stuff like “ new clutch”, just had transmission work done, just passed smog check, and now trying to sell a perfectly running car just does not add up.. something is missing.
Buyer beware!
Buyer beware!
If I were to bet I'd say something happened to the engine (possibly a bad head gasket), this guy picked it up for cheap and threw another used engine in it (with an unknown amount of miles). You could check the VIN on the engine to see if it matches the body. The VIN tag, if I'm remembering correctly, is on the back side of the block just above the oil pan.
Both driver's and passenger's airbags were recalled on these cars. Common SRS code is for the driver's seat belt buckle as mentioned.
As for the seatbelt receiver..is it essentially just indicating that the seatbelt is not properly secured in the receiver?
See the links in my signature
I may be blind...or just new to this forum, but you signature is not displaying at the end of your posts. :-/
Guess I'll head to Honda and see if they can pull any codes.
Check your VIN for any needed recalls at
recalls.honda.com (USA)
recalls.acura.com(USA)
honda.ca/recalls(Canada)
acura.ca/recalls(Canada)
Recalls are always FREE to you!
CHECK YOUR VIN REGULARLY because Honda is continually adding cars to the list and replacing again some parts that have already been replaced!
I may have only enabled the sig on my last post. Here's the links
Hondaman4ever
32
Mar 3, 2018 02:30 AM
old car fan
38
Jan 14, 2016 02:53 PM
jmason
Oct 21, 2015 10:25 AM
i2097i
18
Aug 6, 2010 06:43 PM
