How Much HP From......
Old May 28, 2009
Snowboardruls04's Avatar
Snowboardruls04 is an unknown quantity at this point
I have a 2004 Civic VP i have done the following Mods...
Performance
Aem Cold Air Intake
Obx Throttle Body Spacer
Header (No Cat)
2 1/4" Magnaflow Exhaust
Zex Plugs
Zex 55 Shot Nitrous Wet Kit
Neuspeed Short Shifter
Light Weight Flywheel 8lbs
Stage 2 Clutch
17" rims with Toyo Z 225/35/17 tires
Walbro Fuel Pump 255
And Soon will have installed
Rsx type S 330 Injectors
Aem WIdeband O2
Aem FIC Piggy Back
My question Is where should i be after i tune it and finish the Fuel system? Horse power wise and 1/4 mile wise? I was thinking low 15s Possible 14.9 14.8
Does anyone have this same set up? Or similar? I have run a 16.59 without the 55 shot and fuel pump at 89.5mph
Thanks
2004 Honda Civic Vp
Old May 28, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: How Much HP From......
As for your actual question, I haven't the slightest clue. However, ditch the ZEX plugs, they blow. Grab some NGK's. And if you haven't bought the f/ic yet, I also highly recommend just saving for k-pro instead.
Old May 28, 2009
What would be the benefit of the k-pro over the FIC is it a stand alone? If so why not get the Aem EMS?
