Noob question, auto tranny fluid 91 DX
Rep Power: 0 Noob question, auto tranny fluid 91 DX
I just picked up a 91 Civic DX, owners manual states dexron II for the automatic trans. I thought I read several posts not to use dexron II or III, but to use the Honda ATF instead. Also while changing the spark plugs I noticed one of the plugs was covered in engine oil, not the threads, just the area covered by the spark plug cap. Any words of wisdom? Thanks.
Rep Power: 206 Re: Noob question, auto tranny fluid 91 DX
Use the Honda ATF, most honda manuals say you can use Dexfluid in a pinch for a short time but Honda ATF is highly reccommended. As for the oil on the plug, it's called a spark plug tube seal. They are usually a dollar or less. You will have to pull the valve cover off to change so you might as well change the valve cover gasket too. Here's a link.... http://www.oereplacement.com/advance...Feed%2BTracker
Rep Power: 0 Re: Noob question, auto tranny fluid 91 DX
Thanks, Honda ATF it is. Since I was going to adjust the valves, I guess I'll find out what the plug seals are all about. Much appreciated.
Burnout
07-15-2022 10:24 PM
MajTom
06-02-2015 11:48 AM
