1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
97 Honda civic ex turns over but won't crank
Old Oct 13, 2017
ChuckDeezy's Avatar
ChuckDeezy is an unknown quantity at this point
Ok here's my problem. I was driving through a parking lot and my car shut off as I slowed down. I turned the key and it just turns over but won't crank. The fuel pump comes on and I checked to see if fuel was coming through the fuel filter to the injectors and the flow is very strong. I then checked my wires there isn't any fire coming from them and there's no spark from the plugs. HELP ME PLEASE.
Old Oct 13, 2017
Re: 97 Honda civic ex turns over but won't crank
That's "cranks, but won't start"
No spark: Make sure timing belt did not let go (distributor can't make spark if the cam isn't turning)
Test ignition coil, test igniter. Most crap out the ignition coil before the igniter.
Old Oct 13, 2017
310civicEX's Avatar
310civicEX is an unknown quantity at this point
belt busted...fault codes?
