1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1990 civic wagon stopped now no start
Old Jul 28, 2017
chrokeva's Avatar
chrokeva is an unknown quantity at this point
Have a 1990 civic wagon, last night after starting it started jerking a little while running. After getting on the freeway it began to cut out and you could watch the tach go to zero then back up again. it finally died and coasted off the freeway. I was able to restart it and got it in a parking lot, after that it would not start. am going to check to see if it has spark but if it does where would be a good place to start. also if it doesn't have spark where would be a good place to start also. Car will turn over . Thanks
Old Jul 28, 2017
Re: 1990 civic wagon stopped now no start
Tach dropping would kinda make me want to check for spark (spark, coil, signals to the coil, etc.) and suspect the igniter may have failed.
Old Jul 30, 2017
chrokeva's Avatar
went to the car today with a spark tester, thought I'd try to see if it would crank over first and it started right up. got out and let it idle after a few min. it died then I put on the spark tested and no spark to the plugs. have to charge up the battery for further testing but will check the cap next then the coil.
Old Jul 31, 2017
mac25's Avatar
Dr Krieger of Modification
I'm calling alternator/battery, on this one.
Jump it, if it starts hook up a multimeter/voltmeter if you do not see 12.5-14.5 volts while the car is running, your alternator is cooked.
If it will not jump, swap in a known good battery and try to start it, then test alternator as well.
Old Aug 21, 2017
jockellis's Avatar
jockellis is an unknown quantity at this point
Take off the distributor cap and make sure all the spade connections are properly connected on the coil. They can look alright but still just be touching. I know because I replaced the original, worn out cap with a third party cap and the coil. This caused problems before I bought and installed a new cap and coil. When I cleaned coil #2, I found one set of male and female connections were not having dex; he was just rubbing it against her leg.
Last edited by jockellis; Aug 21, 2017 at 12:16 PM. Reason: Remembered something important
