1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
AC retrofit
Old Jun 6, 2017
ngm's Avatar
ngm
ngm is an unknown quantity at this point
AC retrofit
Can you install a complete R-134 AC system from a 1995 Civic LX into a 1993 Civic LX? The '93 does have R-12 AC now.
Old Jun 6, 2017
Re: AC retrofit
You could convert the 93 to use R134a instead of doing a complete system swap
Old Jun 7, 2017
ngm's Avatar
ngm
Re: AC retrofit
Thanks for your reply. I've been running a R-134 conversion for a few years now but can't stop the leaks at the high side Schrader valve adaptor. That's why I want to change out everything
Old Jun 7, 2017
Re: AC retrofit
Try another adapter?
The car bodies are pretty much the same (as long as you get the same # of doors, sometimes that makes a difference) so if you have a donor car to get parts from it will likely be a straightforward swap.
I'd probably try swapping over the line with the leaky valve in question first and if it fits, run it like that....... because I'm lazy like that.
