1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 Civic EG hatch running rich (D16)
Old Mar 27, 2017
theRedhatch's Avatar
theRedhatch is an unknown quantity at this point
my hatch has been running rich since i bought it, oil smells like gas and the cold air intake filter smells of gas, havent checked the spark plugs yet but if i gap them more will they burn off more fuel? its a d16 swapped into the CX hatch with a del sol ecu i was told...assuming because the d16 came from a del sol but i dont know....
anyone have any input?
Old Mar 29, 2017
Re: 92 Civic EG hatch running rich (D16)
Bump any little input would be helpful guys...don't know why it's running rich don't want to mess the engine up
Old Mar 29, 2017
Douggyf's Avatar
Douggyf is an unknown quantity at this point
You 1st need make sure the ECU is from that vehicle after that make sure fuel pressure isn't too high injectors working properly double check spark plugs mass air flow and kind of work from there
Old Mar 30, 2017
Ok cool I was told the ecu was from a del sol, I'm assuming because the engine is from a del sol too? Not sure
but as far as the mass air flow how do I Check if it's working?
