1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Bubbly noise from clutch pedal at high rpm??!
Old Mar 8, 2017
theRedhatch's Avatar
theRedhatch is an unknown quantity at this point
1992 Civic hatch si just bought few weeks ago starting to have a bubble noise when I shift at higher rpm and I hear some ticking when I turn...hopefully the ticking is just a cv joint but the clutch noise is sounding funny any ideas?
Old Mar 10, 2017
GolNat's Avatar
Prelude Owner
Re: Bubbly noise from clutch pedal at high rpm??!
Can you post a video?
Old Mar 11, 2017
Yea can I upload one to YouTube here in a little bit
Old Mar 11, 2017
Shoot I can take get the sound to get loud enough on camera I have straight pipe but it's like a rusty spring is unwinding and kinda sounds like thick bubbles idk how to explain, is that sign of air in the system? It shifts fine and all
Old Mar 11, 2017
Uploading a video now
Old Mar 11, 2017
Old Mar 11, 2017
GolNat's Avatar
Prelude Owner
Sounds like rusty sprimg you said? Look under the clutch pedal and see if anything is worn. With the car off stick your head down there and work the clutch with your hand. Might just be a worn return spring or something.
Old Mar 12, 2017
when i press the clutch whether the car is on or off its fine, the sound starts if i accelerate slowly then a little more to get higher rpm by that time its making the noise before i even touch the clutch, it only happens in 1st and 2nd and only happens 2/3 times i drive
the only way to explain is it sounds like the clutch has its own catback exhaust system and its backfiring lol i guess il just drive it for now until it seems bad then replace the whole system or just bleed the clutch system
Old Mar 12, 2017
GolNat's Avatar
Prelude Owner
Sounds like a good plan. I would think of it was hydraulic related it would also do it while the car is off but maybe it's after the fluid gets warm. Could be transmission related like a throw out bearing or something. I couldn't really tell from the video. I'll try taking a listen with some headphones later today.
Old Mar 13, 2017
thanks man...yea i hate when i hear something and know someone around the world knows exactly what that noise is lol
Old Mar 13, 2017
Would clutch throw out beating do that noise
