1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Engine rebuild question for first timer
Old 04-01-2015
Fatherofthree13's Avatar
Fatherofthree13 is an unknown quantity at this point
So here is my question. I have acquired a1994 honda del sol with a seized d15b7 engine. Do I bore the d15b7 out or go with a different engine? I am going to rebuild whatever I put in. I have been wanting to rebuild an engine for quite some time. I figured what better place to start. The del sol looks like it will be a blast to drive plus gas mileage is great for a dd. I am an electrician by trade for the past 20 years and have rebuilt things like tractor tranny, motorcycles, etc. I have just never done a complete engine. I have all the tools necessary to do this job. I am just looking for pointers on whether or not I should stick with boring block or get junk yard engine to rebuild?
Fatherofthree13 is offline
Old 04-01-2015
Re: Engine rebuild question for first timer
If it seized, you can probably expect crank/bearing/block/rods/piston issues right off the bat, and that usually isn't cheap. Machine shop work is not cheap either.
I normally would not try to save a seized engine due to cost, unless it's rare and valuable.
You can open it up to find out why it seized, and see how bad the damage is and go from there....call around, get estimates, compare different approaches.
IMO you would probably be better off and cheaper to locate a good used engine (or a completely different running engine) and of course freshen it up before install.
car-part.com
JMHO, YMMV
HTH
ezone is offline
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
sccarally
Texas
05-17-2015 10:11 PM
zack22490
04-29-2015 03:17 PM
Uncle X
04-15-2015 09:59 PM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: Engine rebuild question for first timer
