1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
'94 Si:ECU questions
Old May 11, 2013
Clockwork7's Avatar
Clockwork7 is an unknown quantity at this point
I realized today that I have the acura ecu in my si...will getting a new ecu change anything besides the check engine light coming off? Currently I have aftermarket exhaust and intake, but that's the only engine/power mods. Does an ecu need to be programmed to changes you make in the system? I'm really in the dark on this one.
Help! Thanks.
Old May 11, 2013
Re: '94 Si:ECU questions
Why?
I don't think you have anything listed that would create a need to change it yet JMHO.
Old May 11, 2013
Clockwork7's Avatar
Originally Posted by ezone
Why?
Because the guy who owned it before me put it in. I assume there was something wrong with the original, but I don't know for sure.
Old May 11, 2013
Clockwork7's Avatar
What WOULD create a need to change it? A turbo?
Old May 11, 2013
Yes. Turbo, a big cam, or serious internal mods that would require a significant change to the amount of fuel and/or timing needed to run properly.
CAI and pipes don't cause that need IMO. Stock ECM/PCM can compensate for those without a problem. IMO.
If the engine runs good with the ECM you already have, I'd leave it alone for now.
Is the ECM from an Integra or what?
Is the engine also a swap? Hopefully from the same car?
Old May 12, 2013
Clockwork7's Avatar
The ECM is from an integra, yes. No engine swap occurred though. Still have the original D16 in there.
The engine runs fine, except sometimes during idle it revs up and down at first then settles at a normal rpm. (This could be something else entirely, although i just replaced the oxygen sensor and it changed nothing.) During autocross last weekend it performed well and seemed to have the power I thought it would.
Old May 12, 2013
What's the part number on the ECM? I'm curious if it crosses over to a Honda, since the Integra is nearly the same.
Look into coolant level and flow, and sticking IAC (or FICV if it has one, bottom of throttle body).
The FICV needs to be getting antifreeze just as fast and just as hot as the rest of the coolant in the engine, in order to keep the idle speed right for any given engine temperature.
If the coolant is full: At that age, I'd expect clogged passages anywhere in the circuit of small hoses. Stop-leak really messes these up too.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
