1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
boosted d16z6
Old May 8, 2011
Knox's Avatar
Knox is an unknown quantity at this point
boosted d16z6
I'm turboing my d16z6. I have a stock bottom end with a. 70 trim gt35r turbo with rc 750cc injectors. I was wondering how much boost is safe for the stock bottom end and how much hp I should be pushing at x amount of boost. And I would also like to know if this big of a turbo would cause problems
Old May 9, 2011
MindBomber's Avatar
Live for the Twisties
Re: boosted d16z6
Above 8 psi you should have head studs, above 16 psi you need to have a built bottom end, I wouldn't daily it on more than 8 psi without building it because you'll have reliability issues.
How much hp you make depends on many the tune, not just the psi, you will probably be a little below 200hp.
The big turbo will spool slow.
Old May 9, 2011
Knox's Avatar
Re: boosted d16z6
Do you think that the injectors are to big for a stock boytom end car running low boost?
Old May 9, 2011
MindBomber's Avatar
Re: boosted d16z6
The injectors are massively oversized for your set-up, you might only use half their full capacity.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Klame9420
Aug 13, 2015 06:00 PM
