1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 DX problems
Old Apr 25, 2011
will95DX's Avatar
will95DX
will95DX is an unknown quantity at this point
95 DX problems
Ok so I bought a 95 civic dx hatch and the original motor was a d16y7 it has the Y7 block but the guy I got it from putt a z6 head on it and that's the way I bought it, I've had the car for about three months and now I have a rod knock so im looking for a new motor so I was wondering can I just go pull a d16z6 out of the same year ex can I just drop it in my car and if not what can I do without changing the traney and ecu? Anything will help at this point. Thanks
Old Apr 25, 2011
Civvyftw11's Avatar
Civvyftw11 is an unknown quantity at this point
Re: 95 DX problems
The original engine your car was a d15b7, the guy you bought if off swapped in the d16y7 block with the z6 head. I don't know much about mini me swaps, but im assuming he had to get the p28 ecu and he wired the car for vtec, if thats the case, then you can drop in a d16z6 without having to worry about getting a new ecu/tranny/wiring etc. To be sure, check your ecu model and check your wiring harness to make sure it is vtec ready. Also I'm pretty sure d15 and d16 tranny's are interchangeable but you may want to do some research to double check
Old Apr 25, 2011
lazlong's Avatar
Re: 95 DX problems
Yeah, they're interchangeable.
Z6's came in all Civic EX, SI '92-'95 and all DelSol SI
Old Apr 25, 2011
will95DX's Avatar
will95DX
Re: 95 DX problems
Ok thanks for all the help, it is wired up for vtec ill just have to go pull the ecu code and make sure its the p28.
Old Apr 25, 2011
will95DX's Avatar
will95DX
Re: 95 DX problems
Wow, ok so I pulled the ecu code on my car and its the stock ecu for the d15 that came in my car now what do I do?
Old Apr 26, 2011
lazlong's Avatar
Re: 95 DX problems
Did it drive, idle, and rev correctly before the rod knock? Did VTEC engage? D15s never had VTEC. If it did run right, then just go with what you have.
Old Apr 26, 2011
will95DX's Avatar
will95DX
Re: 95 DX problems
Well I have a buddy that has a 92 ex which is vtec and I smoked him so I would assume my vtec engaged and I've never had problems with starting or idle
Old Apr 26, 2011
lazlong's Avatar
Re: 95 DX problems
^^Well, you have a hatch (which weights less than the coupe) with an engine just as fast 'cause of the swap.
Should be able to get any D16 bottom end and switch your heads to it.
Old Apr 27, 2011
will95DX's Avatar
will95DX
Re: 95 DX problems
So I can bolt and d16 motor up to my tranny?
Old May 22, 2011
HommeDeBois's Avatar
HommeDeBois is an unknown quantity at this point
Re: 95 DX problems
If you have the s20 tranny (original to the DX), it should bolt up just fine. You may want to pull your ecu and look and see if it's been modded for vtec. If not, I would suggest putting in a vtec ecu.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
