1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1993 Honda Civic DX Couple of Questions
Old Feb 21, 2011
Travieso's Avatar
Travieso is an unknown quantity at this point
Hey guys i just purchased a car From Craigslist and im hoping i joined the right forums for some very usable knowledgeable information.
Year: 1993
Model : Honda
Model: DX
Mileage 183,000
Transmission: Automatic
Here are my questions
Knowing that DX's Models dont come with A RPM Tach Gauge if i get a Tach Gauge from 1993-1995 Honda EX is it plug and play?
looks like i could get my hands on one that comes off a 1994 Honda Civic EX.. the extra one i have has 224,XXX miles and the one i have (currently in vehicle now STOCK) has 183,XXX how do i go about changing this to the correct mileage ?
Second question what type of motor does my Civic has i've done lots of research but its all gibberish for me d16,d18 ? and transmission.
Im not looking to modify this civic i bought it for gas mileage since gas prices are going up my v8 is getting very expensive.. what are the mods i could do do to get the best mileage for this car ?
thanks in advance
Old Feb 22, 2011
Travieso's Avatar
Re: 1993 Honda Civic DX Couple of Questions
anyone?
Old Feb 22, 2011
lazlong's Avatar
1. don't know, should be.
2. find the speedo guy or the Honda guy in your area. It's about $300 at the dealer.
3. if it's stock it's a D15. stand in front of the car and look at the block between the. it should be stamped somewhere around here:
4. for better mpg you can change all the filters, change oil regularly; and clean the IACV, throttlebody, EGR, and PCV once a year. wouldn't hurt to put fuel system cleaner in every couple of tanks.
Old Feb 22, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Yes the cluster will work for you and it is plug and play. To change the mileage, just unscrew the whole speedo gauge from your cluster and put in the in the new one. They are the same size.
Old Feb 23, 2011
Travieso's Avatar
sweet thanks guys i got the new cluster.. now i'm a little confused you said i could unscrew the old speedometer and put it to the new one? i notice in the back there was 3 screws holding something im hoping this will be it..
also another question looks like i found the LCD clock display that goes on the side of the AC vent... mine doesn't have it... im hoping the wire to plug in the digital clock is already there anyone of you have done this mod before ?
anyways i added a picture so you guys could see what im talking about
Uploaded with ImageShack.us
Old Feb 23, 2011
MindBomber's Avatar
Live for the Twisties
Those clocks came on integras not civics, I doubt the wire would be there.
Old Feb 23, 2011
Travieso's Avatar
just confirmed myself the wire is there for DX models too just with a black covered on.. i snapped the new LCD Clock and walla it works.. im about to do the Cluster swapped here pretty soon..
Old Feb 24, 2011
TiggerDX's Avatar
I would have thought it would be there as mine came with the clock.
Old Feb 24, 2011
Travieso's Avatar
not DX models i believe they only came in EX and LX but for sure not DX, if yours is a DX model they probably put one in..
Old Feb 24, 2011
TiggerDX's Avatar
I have a DX model. It appears to be very stock but I didn't buy it new. Mine is a 94 though so maybe they added them for the next year, or maybe it was an added option. But I guess I was meaning to say I would have thought the wire to be there already. Honda seems pretty good about pre-wiring most things.
Old Feb 25, 2011
Travieso's Avatar
tigger you're correct it was pre-wired already..
Old Apr 17, 2011
tvang021's Avatar
tvang021 is an unknown quantity at this point
this question is related to his if my car is manual does the other cluster or gauge have to be manual or can i just put in a auto gauge
any wiring i'll have to do thanks
please expain if i have to rewired thanks
Old Apr 20, 2011
TiggerDX's Avatar
The only real difference is the gear lights. The auto has the gear setting lights on the fuel/temp side. As long as you don't care about that everything else should be the same.
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
