1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Clock
Old Apr 4, 2010
PurpleCivic93's Avatar
PurpleCivic93 is an unknown quantity at this point
Question Clock
My clock restarts back to 1 o'clock everytime i turn my car back on. I have a feeling it has to do with my battery because my lights dim and none of the settings on my head unit save when i turn my car back on either. Please help
PurpleCivic93
Old Apr 10, 2010
angrysmileyface's Avatar
angrysmileyface is an unknown quantity at this point
Re: Clock
Battery is weak. Had this problem a month ago. Eventually got to the point where it wouldnt even crank the car without a jump. Have the battery tested at Autozone or Advance Auto
Old Jun 23, 2010
voxleo's Avatar
voxleo is an unknown quantity at this point
Re: Clock
+1 on battery issue. Especially even if its a new battery - check the connections for corrosion or any wiggling that might make contact iffy.
Mine was due to a loose connection on the neg terminal (probably due to a jump start I got after leaving the lights on in the daytime). What was horrifying was that I turned the key and then everything went completely dead without any warning as if something blew a fuse.
Old Jun 16, 2011
voxleo's Avatar
Re: Clock
UPDATED:
Though this was not my original problem, additionally, I recently have had opportunity to experience this dimming clock/1:00 reset and found that the backup fuse under the hood is responsible for this specific 1:00 problem - it is the 7.5 amp that needs replacing..
Marco83
Oct 13, 2018 10:13 PM
tropicola
Sep 25, 2015 07:02 PM
speedlever
Sep 24, 2015 07:18 PM
0396
Aug 21, 2015 05:27 PM
