1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Fuel and Temp Gauges stopped working!
Old Jul 15, 2009
siwel177's Avatar
siwel177 is an unknown quantity at this point
Exclamation Fuel and Temp Gauges stopped working!
I bought a 5th gen EX gauge cluster to swap into my 92 CX off ebay so i could have a tach. The tach and spedo work fine after the swap, but the fuel and temp gauges do not. I was told that the entire cluster worked fine when it was removed, so im assuming that something happened during the install. I checked the plugs in the back of the cluster, no problems there. I checked the gauges themselves, also no obvious problems.
I really need some advise here! Any ideas on what could be wrong???
Old Jul 19, 2009
revr63ed7's Avatar
revr63ed7 is an unknown quantity at this point
Re: Fuel and Temp Gauges stopped working!
The terminal pins are in different locations for fuel gauges between years and models, even between different engines.
Old Jul 20, 2009
siwel177's Avatar
where are the fuel terminals located on a 92 civic CX with the canadian 16 valve 1.5?
Old Jul 20, 2009
revr63ed7's Avatar
your best bet is to lay both clusters side by side and trace the signal wires to the connector. see what pin cavity your old fuel gauge goes to, then you can find the wire in the corresponding plug on the harness. then find the terminal for the fuel gauge on you new cluster. move that wire to that cavity in the harness plug. As i remember some are in cavity 10 and others in 12.
Do you know what year and engine the new cluster came from?
Old Jul 20, 2009
siwel177's Avatar
well i'll try that.
it came out of a 94 ex, not positive on the motor, think it was a 1.6?
Old Jul 20, 2009
revr63ed7's Avatar
Ok, i've just gone through the wiring diagrams for every civic model 92-95 and they are all the same. I'm not sure if my diagrams cover canadian. What I did see is that del sol wiring is different. I'm not even sure if a del-sol would fit. Here's something that may help, I have the diagram but don't know how to post it. the temp wire is in connector c510 terminal #4 and is yellow/green.
the fuel gauge wire is in connector c-511 terminal #12 and is yellow/white.
Be sure to check your connections where the harness plugs into the cluster.
Good luck!
Old Jul 21, 2009
siwel177's Avatar
could you email the diagram to me?
clewis177@yahoo.com
Xuhme
21
Aug 7, 2023 03:40 PM
ORskier
May 3, 2015 12:54 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CivicLX2001
Nov 16, 2001 06:33 PM
