1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Problems with D15b7
Old Apr 11, 2009
punkey871's Avatar
punkey871 is an unknown quantity at this point
Problems with D15b7
Hey i have a problem with my engine it rotates but will not start i have tried everything! From re-timing to adjusting the cams! The pgm is working fine the fuel injectors are working! The injection system is fine everything works! The fuel is fine no water in it! I have also checked all me connections on my wiring harness and nothing is lose or broken! I also checked the ecu and its fine no codes in it! Help please its been down for 3 months now and im desperate!
Old Apr 11, 2009
JDMCivic95's Avatar
JDMCivic95 is an unknown quantity at this point
Re: Problems with D15b7
Hey, if it cranks...thats a good sign...try your distributor, cap and rotors...change out your spark plugs. Change the cap and distributor, those go bad inside the spark modual..how many miles does your civic have?
Old Apr 11, 2009
Civic-Dude92's Avatar
Civic-Dude92 is an unknown quantity at this point
Do you get spark if not main relay may be bad
Old Apr 12, 2009
punkey871's Avatar
yes there is spark i have checked that
Old Apr 13, 2009
CG89DXHB's Avatar
CG89DXHB is an unknown quantity at this point
you may have a weak fuel pump, try cyclign your key three to 4 times then starting it or cycling, "bumping", the engine a few times before trying to start it, as this will give necessary fuel.
i had a similar problem in my 89 DX stopped at a gas station and it wouldn't fire back up so i could back up to the pump as i pulled a little to far forward..
also, if that doesn't work, try doing a compression test, and how is the motor soundign when it spins over? does it sound like a drill? or have an uneven rotation? if it spins liek a drill you probably bent your valves and have no compression, if it's uneven, you may still have bent some valves, also check cam timing, and if your positive you didn't bend valves, open your rad cap when you turn it over and see if there's any fluid or pressure exiting the radiator with the cap off, if there's little to no fluid, or pressure exiting, you probably popped a head gasket, also do a vacuum gauge check, to see if maybe your intake gasket went out.
for a no start condition, this is all the things i would look at, as i've run across these problems on customer vehicles, you could also pull the dipstick and see if you got antifreeze in with your oil that way to check for a popped head gasket or possibly even worse.. cracked/warped head. hope it turns out to be something simple and easy to replace.
Old Apr 13, 2009
CG89DXHB's Avatar
OH.. and is your spark blue/white or orange? if orange it is weak spark and you could be blowing it otu before it ever get's the chance to ignite anything..
Old Apr 13, 2009
wrightdbs's Avatar
wrightdbs is an unknown quantity at this point
Will not start ever...period?
either...
No Fuel
No Spark....
...Said you have spark.
Fuel? You can download a manual pretty easily...check the fuel pump/injector run circuit....
Had a similar problem in an older honda....Bad Main Relay...gave me FITS!
Pr0n1s
Apr 30, 2015 03:08 PM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
