1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 1.6 hard to start
Old Dec 16, 2008
robbanks111's Avatar
robbanks111 is an unknown quantity at this point
I have a 95 1.6 civic it turns over for say 20 seconds sometimes before it will actually start. Does it have a pre-injector? and if so where is it located. thanks in advance.. btw it runs fine when it finally does start.
Old Jan 5, 2009
Neutrilizer's Avatar
Neutrilizer is an unknown quantity at this point
Re: 95 1.6 hard to start
The fuel pump should prime when you turn the key forward before you start to turn it over. It should make a slight whining noise. I'd get someone to test your fuel pressure.
Old Jan 23, 2009
CivicMafia's Avatar
CivicMafia is an unknown quantity at this point
Go through the routines.
Check Fuel Pressure, check your spark and your rotor buttton if it is loose it will have a delayed firing, I know from a personal mistake ~.~
Old Feb 23, 2009
FreddieG's Avatar
FreddieG is an unknown quantity at this point
Same problem here I am going to look at these things as well.
jbradley4809
Apr 7, 2017 04:23 AM
Shakzhussain
May 17, 2015 12:03 PM
MamaBear2015
May 3, 2015 02:17 PM
TaiChi
Dec 17, 2001 09:09 PM
black2k1vtec
Dec 6, 2001 09:49 PM
