1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
how do i know my engine size
Old Sep 5, 2012
93honda's Avatar
93honda is an unknown quantity at this point
Hi I own a 93 civic ex and I'm confused about what engine I have.. it says v-tech but it doesn't say 1.6 or 1.5 now I was told by the guy that sold me the car that it isn't the stock engine and I'm no longer able to find his number to call n ask him .. how do I find out?
Old Sep 5, 2012
Re: how do i know my engine size
Lookie about right here
That was not a civic engine, BTW.
You should see a set of numbers like this
In this number, the 16 means the block is a 1.6 liter engine block.
Post your engine code (this one is D16Z6), I'm sure someone can tell you what it started life as.
HTH
Old Sep 5, 2012
93honda's Avatar
HTH
So I have an engine that doesn't belong in my car.. that would explain my mileage a bit less then I thought hahaha
Old Sep 5, 2012
93honda's Avatar
HTH
So since that's not a civic engine how do I go about asking for parts at the local parts store?
Old Sep 6, 2012
It does not matter that I posted something that wasn't a Civic engine. I posted a pic of A Honda engine.
The engine in YOUR CAR will have AN engine number stamped into the flat area, just like the pics above that I FOUND on Google and linked in the earlier posts.... All Honda engines have a stamp similar to those I FOUND on Google.
The engine number is a code.
Find your engine numbers. It will be stamped into the same area as where the first pic has the red square.
Read your own number. You might need to scrub it with a wire brush to read it clearly.
Post it here.
Someone
can tell you what the engine came out of, once you post your engine number....
Or maybe search here for the chart with most of the engine codes, match up the numbers off of your own engine.
Someone could have stuffed an engine from an Integra or a Prelude in your car, for all I know. Nobody here can know what is in your car until you post the engine numbers from your engine.
If you go into a parts store and try to order parts using only an engine number, the counter help will probably stare at you as if you have two heads. They need to know what car the engine came from.
You will have to know when to order certain parts for the car you have, and when to order for the car the engine came out of.
HTH
Old Sep 6, 2012
Here, watch this crappy video. The guy points where you need to look on your engine.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1296& transactionid=1346909178-982224733&posted_by=ezone_www.civicforums.com&yout ube_video_id=cZ5WKbJzpxY[/autostream]
Old Sep 6, 2012
93honda's Avatar
Hell yeah that was a crappy video.. No abla espanol lol atleast I can understand sign language
Old Sep 6, 2012
93honda's Avatar
Post it here.
Someone
HTH
Well it's d16z6 which like u said is the 1.6L and it is for my Honda civic. Thanks a lot
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
