B20z
Old Oct 19, 2002
sauado's Avatar
sauado is an unknown quantity at this point
B20z
how many hp does B20z have in stock?
is it good to swap in a 6th gen civic
Old Oct 29, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
I ran a search and got This - maybe that would help?
Old Nov 1, 2002
quicksi's Avatar
quicksi is an unknown quantity at this point
B20's are fine to swap into a EK, but there is alot of work that needs to be done in order to swap in. 1st you need to know what you are looking to do, LSVTEC, or CRVTEC or just straight B20 conversion. I assume you have a non Vtec model?
Old Nov 7, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
http://www.importbuilders.com/cratedmotors.html
http://www.importbuilders.com/block.html
Old Nov 20, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
good question, will it be HYBRID B20 w/ Vtec head or just a straight B20?
the B20Z has higher compression than the B20B. if you ever plan on doing a turbo, go with the B20B block. then as far as heads go, i think you can take your pic from all the B series Vtec heads. using the B16 Vtec head, you must be VERY CAREFUL not to let the pistons hit the valves, because this hybrid is a very close fit. a block guard might be the way to go on that one. i just spent the last week or so going through all my import mags from the last year or so, and cutting out all the "HYBRID-HOW-TOs", and i must say that i've learned SOO MUCH! if you're interested in hearing what some of the articles have to say, you can either try emailing the magazines for answers on this swap and how to build the hybrid, or you can try emailling me with specific questions, and i can email you back the answers that i've gotten from these articles.
- KillerBHatch@aol.com -
Old Dec 3, 2002
JDMCivicHatchSiR90's Avatar
JDMCivicHatchSiR90 is an unknown quantity at this point
dude....i think that getting a B20 is better then b16 or b18 because a lot of peeps get the same thing....not a lot of peeps get B20.....i think B20 is the way to go (but then again thats what i think[IMG]i/expressions/face-icon-small-wink.gif[/IMG])
Old Jan 1, 2003
dragoon's Avatar
pros of a b20:
1) larger displacement
2) usually cheaper than a comparable b16 or b18
cons:
1) more work involved, often vtec is desired, so you have to mate a vtec head from somewhere onto the block
2) people say b20/b16a(or b18c, blah blah) hybrids aren't as reliable and require more frequent maintenance
Old Jan 9, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
What is CRVTEC? does that have to do with the CRV? also is there a web page where i can learn about B series motors... LS/VTEC conversions and so forth?
chris00SI
Jun 20, 2012 08:03 AM
chris00SI
Jun 8, 2012 03:18 PM
MindBomber
Engine Swaps
Sep 17, 2011 01:15 AM
MindBomber
Mar 19, 2011 08:31 PM
Kung
Engine Swaps
23
Nov 18, 2004 07:39 PM
