Bad regulator?
Old Feb 10, 2018
g4384063's Avatar
g4384063 is an unknown quantity at this point
Bad regulator?
Hello all,
LR power window won’t stay up, keeps sliding down.
Took panel off, to test and noticed this piece pops out of track.
Is this, more likely?
1) Bad regulator
2) “Windows Bind or Come Out of the Run Channels” per Honda Service Bulletin 98-082
3) Other issue
BEFORE:
AFTER:
Old Feb 10, 2018
Re: Bad regulator?
Needs a regulator.
Fish around in the very bottom of the door for a rectangular chunk(s) of plastic the width of that track, I bet it fell down there in pieces..
Old Feb 10, 2018
g4384063's Avatar
Re: Bad regulator?
Originally Posted by ezone
Needs a regulator.
Thanks!
This is what I found, in the bottom of the door...
Old Feb 10, 2018
Re: Bad regulator?
Well okay the round piece wasn't the rectangular chunk I had in mind, but then I see so many different cars I can't keep all the differences straight.
Yeah you found the broken piece. Replace regulator assembly.
The black chunk looks like the bottom travel limit cushion (for lack of a real name) so it doesn't make that metallic clunk when the window stops at the bottom.
Old Feb 12, 2018
g4384063's Avatar
Re: Bad regulator?
Thanks!
How confident are you it’s regulator assy, not a damaged glass run channel or other issue?
Is regulator assembly aka “Power Regulator” part# 04726-S01-A01?
FWIW: Glass Run Channels:
Old Feb 12, 2018
Colin42's Avatar
Re: Bad regulator?
he's a honda mechanic, probably pretty confident
Old Feb 12, 2018
g4384063's Avatar
Re: Bad regulator?
@ezone, No disrespect, intended!
Just want to be as sure, as can be, over the Interweb, before I pull the trigger...
"Power Regulator” part# 04726-S01-A01 in my cart.
Old Feb 12, 2018
Re: Bad regulator?
04726-S01-A01
Looks like it fits 96-00 Civic 4 door sedan, left EDIT: REAR
I can't tell much about the glass run channel from here..... did the glass ever bind or come off track before the regulator broke? Jam up when it gets near the mirror?
Google search for Honda bulletin 98-082 for info about binding or jumping off track
Old Feb 12, 2018
g4384063's Avatar
Re: Bad regulator?
04726-S01-A01
Looks like it fits 96-00 Civic 4 door sedan, left front
Thanks!
04726-S01-A01 is "Regulator Set, L Rear Door (Power)", per VIN search, which is the side & door, I have issue with.
Stuck hand up and felt along both sides of channel, plus looking at pics...No apparent damage. Not aware of, glass ever binding or coming off track before the regulator broke.
No mirror on L rear door.
Old Feb 12, 2018
Re: Bad regulator?
Shoot me now. I can't even read.
04726-S01-A01 Left REAR door.
Now that I understand.....It was front doors that had the binding and jumping off track problems. Rears didn't have a tsb.
Old Feb 12, 2018
g4384063's Avatar
Re: Bad regulator?
Thanks, that's very helpful!
Ordering!!
SynisterRacing
Dec 12, 2002 12:04 AM
Parisdreams
Dec 2, 2002 05:26 PM
2k2civicballer
Jul 30, 2002 10:11 AM
fourkilos
Apr 3, 2002 08:30 PM
