1997 civic throwing check engine code p0705 transmission range sensor
Hey recently swapped the motor in my 1997 civic coupe automatic. an got it all running good an now when i took it for a drive it doesnt shift right you have to put the pedal almost to the floor to get it to kick down to even speed up an once it does it starts to slow down until i get it to kick down again. took it too the part store an it threw code p0705 transmission range sensor and i cant find were that is on this car nor do i know how to go about fixing it
Re: 1997 civic throwing check engine code p0705 transmission range sensor
P0705 shouldn't be a code in that car.
Maybe you mean P1705?
If not, try a different code reader first.
You have a full set of lights in the gauge cluster that tell what position the shifter is in. Do they light up and show the correct shifter position?
It defiantly said p0705 lol. Why is it not suppose to read that code? Yea they all lights light up an looks like the lights change positions when there suppose too
Hondas service info does not list that code for that year and model US cars.
That means the PCM is not supposed to be able to set that code.
That means the code reader is probably giving a false interpretation (it's a known problem with some readers and scanners).........so try a couple other scanners before you jump off the deep end.
Yea i seen that it wasnt suppose to throw that code but i didnt know why. I was gona find that plug thats under the passanger side dash tomorrow an jump it to see what code it throws that way. Does it matter that the motor was swapped to a jdm zc 1.6 for tbat code to come up?
Far as i know its stock pcm i didnt change it. I wonder why it threw that code then? I was also gona check fuses too see if any might be blowed.
It set a code of some sort, yes, but your code reader (apparently) can't read it correctly.
Try different code readers, see if you get different results.
Oreillys was were i used the reader at. An i wasnt gona pull the fuses yet was jus gona look an see if any appear blowed without pulling them. Yea i was gona try to find that plug an jump it an see what happens there an if its no help gona borrow the neighbors reader an try that
Went to move the ecm to get to that service plug an i jumped it an check engine light didnt flash an now damn car wont start checked all fuses
Jamesray8686
Dec 18, 2017 12:51 PM
