Electrical Issue help
Old Nov 15, 2017
BCiv03's Avatar
BCiv03 is an unknown quantity at this point
I have a 03 civic and my headlights dim and my needles on my dash drop all of them , then it'll sometimes come back up I had alternator replaced and battery and I didn't have the issue for a couple days and now I'm having the same problem and also my car idles in between 2 rpm to 1 rpm and it'll slowly go down. I don't know if I got a faulty Alt or something but can someone pls shed some light on the situation. Also now when I try to start the car it clicks fast and then it sounds like it's trying to turn over and doesn't .
Old Nov 16, 2017
Re: Electrical Issue help
Someone forgot to tighten ALL of the alternator mounting bolts? Check those ASAP
New alternator is junk?? Pretty common.
Old Nov 16, 2017
BCiv03's Avatar
Okay I'll check that & see I was thinking faulty Alt but I wasn't sure if I had a wiring issue going on
Old Nov 16, 2017
Old Nov 16, 2017
BCiv03's Avatar
Thank you , I'll message you if I got anymore questions
