96 hatch airbag replacement help
Old Jun 14, 2017
Tony Serrato's Avatar
Tony Serrato is an unknown quantity at this point
Ive searched the forums but cant find a clear answer on replacing my airbags and srs module so if i unplug my battery remove and replace both airbags and srs module connect everything and plug battery back in i should be good right no need to worry about the new bags going off no special codes i have to clear
Old Jun 14, 2017
Re: 96 hatch airbag replacement help
Disconnect battery, wait at least 3 minutes before doing any airbag work.
Then do whatever you need to do.
Reconnect battery when your work is complete.
You'll know in a few seconds if the control unit finds anything wrong.
Old Jun 14, 2017
So probably a safe bet to replace the bags and module frist then replace windshield
Old Jun 14, 2017
Windshield installers probably won't care one way or the other.
Probably no difference either way unless water gets in IMO.
Old Jun 14, 2017
Im more worried about replaceing the windshield and the airbags going off after i plug the battery back in and breaking the new one
Old Jun 14, 2017
Install your SRS stuff first then.
Was this a crash job, or did the bags randomly deploy?
Did you check all SRS wiring?
Old Jun 14, 2017
Was driving and hit a dip on a dirt road (i live in the desert) to hard made them deploy i checked what i can see without removing the dash i changed my two srs fuses and im changing my srs module and air bags anything else that need to be changed from my understanding the impact sensors are in the module i checked suspension everything is good only other thing that needs to be replaced is the driver side motor mount
Old Jun 14, 2017
Looks like that system is primarily the module and bags, no external impact sensors.
