Shifted into reverse at 50 mph. 99 civic help.
Old Jun 4, 2017
Elp619's Avatar
Elp619 is an unknown quantity at this point
Hello all. I have a 1999 civic coupe automatic. A family member said the car would stall at speed, so would drop it into neutral, restart the car and keep going. One fateful night, shifted passed N into R at about 50 mph. Car now has no reverse, but all forward gears work fine.
Quest​ion being: what are my options to to fix the reverse? Cheaper to replace than repair? I can save on all labor, being a mechanic myself. But I am not familiar with the inside of an automatic transmission. Suggestions please. Thanks in advanced.
Old Jun 4, 2017
Re: Shifted into reverse at 50 mph. 99 civic help.
If you think you can, you have nothing to lose by opening it up to see if you can fix it.
At worst, you already knew you might have to replace it.
Apparently you have a pesky stalling problem to chase down as well.
Old Jun 7, 2017
SIngram's Avatar
SIngram is an unknown quantity at this point
I literally just gave this advice to someone else.
It comes down to if your attempt to fix the problem risks doing more damage. If you can't break the thing anymore that it already is already broken, and can't break the things around it by making a mistake... Why not go for it?
