B20 tranny swap questions
Old Apr 17, 2017
Jonas99civic's Avatar
Jonas99civic is an unknown quantity at this point
Hello,
I have swapped out my 99 Civic EX's D16Y8/5speed for a B20B/5speed from a 1998 CR-V. I am in the process of hooking everything up but need to figure out the shift cables and the rear t-bracket.
Has anyone else done this?
Can I use a shifter and cables from a near same year accord for the CR-V 5 speed manual trasmission?
My D16Y8 T-bracket wont work (even with modifications) and the t-bracket I tried to use (Honda part# 50825-S10-A00 for a 2000 Civic si) wont work either.
I have ordered a t-bracket for a 1998 CR-V with hope that it will bolt up.
Any and all help is appreciated!
Old Apr 17, 2017
Re: B20 tranny swap questions
I'm mainly curious to see how many others have installed a cable shift manual tranny into a Civic.
I already have this engine and transmission installed in the car less the T-bracket. I'm pretty sure I can install a shifter and cables from an accord but thought I'd see what others have done.
Old Apr 17, 2017
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Can you just get the shifter and cables from the Crv that donated the engine/trans?
Old Apr 18, 2017
Unfortunately no.
I think the CR-V shifter is taller than a civics. After doing some more research I believe an Accord shifter and cables will work.
Old May 31, 2017
Just to follow up for anyone else that does this...
1) The "T" bracket will need to be from a CRV when installing a CRV tranny into an EX Civic.
2) The Accord shifter and cables that I used had to be slightly modified. A better choice would be to use the shifter and cables that came with the CRV 5 speed tranny. (I didn't have them)
The Civic runs and drives great with the B20B and 5 speed from the CRV!
