Transmission problem 99 ex coupe
Old Apr 17, 2015
Richkid23's Avatar
Richkid23 is an unknown quantity at this point
Hi I'm new to the civic forums but I have a 99 civic ex when I Start the car and let it warm up and put it in reverse and drive in my automatic is slams and you hear a loud clunk drive won't work unless it's in d2 and reverse works fine. Also the Rpms stopped the same time this started acting up if someone could tell me the reason behind this it will be well appreciated FYI the transmission has fluid and didn't leak any
Old Apr 17, 2015
Re: Transmission problem 99 ex coupe
Got any fault codes?
Got any blown fuses?
Old Apr 18, 2015
Richkid23's Avatar
No blown fuses and as for the fault codes Im not sure my cel is on due to o2 sensor but I'm afraid to drive it to autozone and have it break down
Old Apr 18, 2015
Any NEW fault codes? Know anyone with a code reader?
If the light is already on all the time it's tough to know if something NEW pops up.
Old Apr 18, 2015
Richkid23's Avatar
So I brought the car to get the codes check I have code P0141
P0135 P1298 P0450 P0453
P1768 P1753. My guess is that it my be the shift Solenoid. Or the ecu. Car won't shift at all I have to drive it in d2
Old Apr 18, 2015
Check fuse #15 in the dash fusebox.
That might cover many codes at once, many items share the same fuse....
Read this bulletin PDF about the blown fuse: http://www.tegger.com/hondafaq/misc/96-99_civic_mil%26fuse15/99-029_tsb_blown%2315_fuse.pdf
P1768
Problem in clutch pressure control solenoid valve circuit
P1753
Problem in TCC valve A circuit
I'll guess wiring problems for these two, and might be related to the other codes and bulletin posted above.
OTOH, mice can do some fantastic damage to wiring in a hurry.
A good service manual and volt-ohm meter might go a long way toward finding the correct answers.
Old Apr 19, 2015
Richkid23's Avatar
All the fuses are good I checked all the 15's under the dash on the driver side
Midnapore
May 18, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
bo_red
Transmission
May 3, 2015 09:14 PM
Pr0n1s
Apr 30, 2015 03:08 PM
Civicman92296
Apr 23, 2015 09:22 PM
