98 civic with d16z6 cyp error
Old Nov 15, 2013
cannibal_carnie's Avatar
cannibal_carnie is an unknown quantity at this point
OK I have a 98 civic with a d16z6 I got with some rigged wiring. I know it has a p28 ecu that has 1 wire on the ecu plug that is cut I did a pin out and the wire is for the cyp/p and when I pull the error code it shows up error 9 which is for the cyp.my ? Is where should that wire go? The harness for the car was adapted for an obd1 but can figure out where the cyp/p wire needs to go. The dizzy is a 9 wire distributor Ive read about the cpk bypass but the one i read was for a obd2 ecu not obd1 my car currently has a bad miss and Boggs badly when I press gas quickly
Old Nov 15, 2013
Re: 98 civic with d16z6 cyp error
I wanted to know if I could just run 2 new wires to the distributor from the ecu cause there's 2 cyp wires on the distributor and 2 on the ecu
F1wanabe
Apr 27, 2015 11:06 PM
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
