Mini-me Help/ Suggestions
Old May 14, 2013
burgoyne's Avatar
burgoyne is an unknown quantity at this point
Alright, so this payday, I am planning to head to a few junk yards and find myself the parts for a mini-me swap on my y7 engine.
From my research, I gather I need these parts:
-'96-'00 EX Vtec Head Cylinder (from a manual car)
-'96-'00 EX Timing Belt (brand new)
-'96-'00 Head Gasket (brand new)
-'96-'00 Intake Manifold, and Gaskets
-'96-'00 Exhaust Manifold, and Gaskets
-'96-'00 Valve Cover Gasket
-ECU (EX, or a P28?)
-'96-'00 EX Throttle Body and Intake Plenum
-'96-'00 EX Throttle Plate
I will also be purchasing these parts to install since I already have the head apart:
-Brian Crower Stage 1 Camshaft
-OEM Water Pump
I will also pick up a Chiltons manual to help with anything I run into.
Am I missing any parts to pick up?
As far as the ECU goes, should I buy a P28 (and get an OBD2 to OBD1 adapter harness?), or will I be able to take the ECU that is on the EX I remove the other parts from?
Please give me some advise, any help will be much appreciated.
Old May 14, 2013
burgoyne's Avatar
Re: Mini-me Help/ Suggestions
Instead of using a junk yard head, would it be worth it to buy this:
http://www.ebay.com/itm/1-6-HONDA-CIVIC-DEL-SOL-CYLINDER-HEAD-P2J-VTEC-D16Y8-/360612808196?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f632c604&vxp=mtr
Or another re-built head online?
Old May 14, 2013
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
eBay head and junk yard head are the same. You don't know where they got and what condition at least at junkyard you can have a hands feel and see for yourself before you buy
Old May 14, 2013
Lordsin's Avatar
Lord Sin
-'96-'00 EX Vtec Head Cylinder (from a manual car) ((((yes))))
-'96-'00 EX Timing Belt (brand new) (((yes also water pump)))
-'96-'00 Head Gasket (brand new) (((yes)))
-'96-'00 Intake Manifold, and (((NEW))) Gasket (((yes)))
-'96-'00 Exhaust Manifold, and Gaskets (((no the y7 and y8 share the same manifold unless you want a race one or 4-2-1 manifold)))
-'96-'00 Valve Cover Gasket (((the new head should have this)))
-ECU (EX, or a P28?) (((has to be from the ex)))
-'96-'00 EX Throttle Body and Intake Plenum ((( should already be on the intake it not then yes. I don't think you know what intake plenum is)))
-'96-'00 EX Throttle Plate ((( no should already be on the Throttle body)))
-Brian Crower Stage 1 Camshaft ((( why?))) if just staying stock the. It's not needed.
-OEM Water Pump (((always replace when doing timing belt)))
As far as the ECU goes, should I buy a P28 (and get an OBD2 to OBD1 adapter harness?), or will I be able to take the ECU that is on the EX I remove the other parts from? ((( take the one from the ex, with the p28 you need to get it tuned)))
(((Just pm me and I will try to help)))
Old May 15, 2013
burgoyne's Avatar
PM'd you, Lordsin
Old May 17, 2013
burgoyne's Avatar
Would it be worth it to get the head ported and polished? If yes, where could I bring it to get it done?
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
juicetayne
Sep 30, 2015 11:02 AM
anubis62
Sep 27, 2015 12:56 AM
J-Fly
Sep 10, 2015 08:39 PM
