Fram Air Filters
Old Apr 1, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Fram Air Filters
I think I was using the wrong air filter for like 13 years. According to fram's site just for the 1996 civic SOHC the say use a CA8040 (which has noticeable thinner pleats. I was using a CA7764 (thicker pleats) which for the 1997 and on engines.
I am wondering why the change when the engines for 96 til 00 where the same? I wonder if the 8040 would offer better fuel economy or performance since the pleats where smaller?
Just as a side note the I remember the Honda filter looked like the thicker filter.
ID:	78130   Click image for larger version
Old Apr 2, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Fram Air Filters
More pleats=more surface area...hence better flow. The more pleats the better, and keep in mind much better filters than Fram don't cost much more (such as Wix or Puralator PureOne). They filter much finer particles and generally have more pleats than the Fram.
Old Apr 11, 2010
SteelBlueTJ's Avatar
SteelBlueTJ is an unknown quantity at this point
I don't see how you could be running the 7764 filter incorrectly. It doesn't even come close to fitting in the factory airbox. It is square and completely the wrong size. I know because I accidentally bought one to replace mine only then did I realize when I went to install it and noticed it wasn't going to work. The 8040 is the correct filter.
Old Apr 11, 2010
civicpapi's Avatar
The 7764 was in the lookup guide at Walmart, but it fits perfectly you can turn it is not perfectly square., I doubt the air box changed in 98 to 00? don't forget I have a EX not a DX. And like I said it looked identical to the stock air filter from honda with the deeper pleats.
mistermenphis22
Jul 13, 2015 04:43 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
carid
Apr 30, 2015 07:00 AM
silverdevil
Feb 2, 2002 08:54 PM
