Replacing window regulator - tips?
Old Oct 6, 2009
Goldenvoice's Avatar
Goldenvoice is an unknown quantity at this point
96' DX - driver's door - the regulator blew apart, so I have it out, and on the bench, and I'm attempting a repair. The "can", I'll call it, that the crank shaft goes through: the 4 little ears that hold it to the main frame broke off, leaving the shaft flapping in the breeze. So - I'm attempting to repair it, but...
Seems upon installation of either this one, or another, the job will go smoothly if I bolt it back in in some specific order. There's the "rail", the regulator, and the bolts to the glass...
And of course, there's that pesky spring...
Advice?
Oh, and while we're at it, the other side (passenger) - the glass binds, and comes out of the front track if I try to put the window down... The front edge of the glass 'prys' out of it's track toward the outside of the door when the window gets about 1/3 or 1/2 way down - and binds. It's like one of the tracks is bent/misaligned ??? It's a real head scratcher for us at this point...
Old Oct 7, 2009
sql_civic's Avatar
Re: Replacing window regulator - tips?
I had the same problems with my 97 hatch. Just remove the regulator and lube all the moving parts with white lithium grease and reinstall. Follow the instructions in the factory service manual to install the regulator and balance the window.
Old Oct 7, 2009
Yup - a bend regulator - straightened and cleaned/lubed - works well!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
supercivic01
South
Nov 30, 2001 11:27 AM
