Spark plug installation torque specific?
Old Oct 6, 2009
Goldenvoice's Avatar
Goldenvoice is an unknown quantity at this point
96' 1.6L - iron head or aluminum? Are these very specific about torque for spark plug installation?
I don't have an inch-lbs wrench, only an foot-lbs...
Old Oct 6, 2009
Re: Spark plug installation torque specific?
pretty sure aluminum. the factory plug torque is around 13 ft/lbs but i do 20 to be safe so they dont get loosened. try not to tighten any more than that.
Old Oct 7, 2009
sql_civic's Avatar
You definitely have an aluminum head. Honda specs 13 ft-lbs and use a little anti-seize on the threads.
Old Oct 7, 2009
Thanks gang - went smooth as a bunny's butt!
Old Dec 6, 2015
murphdurphest86's Avatar
murphdurphest86 is an unknown quantity at this point
You do not put anything on the threads that will change the final clamping force/torque spec
Old Dec 13, 2015
EdGasket's Avatar
EdGasket is an unknown quantity at this point
Well you should put some copper grease or anti-seize on the threads so your plug doesn't weld itself in there over time. For new plugs you tighten down until you feel resistance as you start compressing the washer, then keep going about a further quarter to half turn with a small 3/8" drive ratchet until you hit a much firmer stop as the plug washer is then fully compressed and your plugs are in tight enough.
The spec. is 13 ft-lb but better to do it by feel I think. If threads are lubricated then derate the torque to about 10 ft-lb if using a torque wrench.
I don't understand that comment above about doing to 20 ft-lb 'to be on the safe side'?? You are more likely to cause yourself grief with stripped threads by over-torquing than 'being safe'! The plugs aren't going to come loose even at 10 ft-lb torque.
Old Aug 1, 2016
javery91's Avatar
javery91 is an unknown quantity at this point
Check out how to properly install here. I dont understand the anti seize cause it messes with the torque in the owners manual.
thana
Jun 15, 2020 07:05 PM
danace99
23
Jun 28, 2015 08:49 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Grey
16
Jan 27, 2002 11:34 PM
