could it?
Old Aug 21, 2009
Scarecrow's Avatar
Scarecrow is an unknown quantity at this point
could it?
Question... on a higher mileage 99 ex.
if the car has been running hard, on a hot hot day, stop and go traffic.
and when i stop to park, pull the ebrake (stick shift) and for whatever reason, if i dumped the clutch and stalled/killed it (thought it was already OFF, cause it runs so smooth).
is it possible to trip the check engine light (knock sensor or some sensor)..??
i dissconnected the bat, it reset fine,
run the car hard the next day, hot hot day, same type traffic (without
stalling it out) and it never had the check engine light.
just wondering if that was enough to trip the light...
thoughts
opinions
happened to you...
anything
thanks
Old Aug 21, 2009
ilikesnackpacks's Avatar
ilikesnackpacks is an unknown quantity at this point
Re: could it?
Possibly....I have never heard of that happening though...Shoulda pulled the code!
Old Aug 21, 2009
Scarecrow's Avatar
Re: could it?
right right... but it hasnt come back. So, it cant be that bad.
Old Aug 25, 2009
Scarecrow's Avatar
Re: could it?
crap.... its back.
well, gotta get a code reader.
Old Aug 26, 2009
Re: could it?
check ebay , i got one for $40
Old Aug 26, 2009
Scarecrow's Avatar
Re: could it?
cool thanks.
autozone is a half block away.... they may have a cheap one...
Old Aug 31, 2009
Scarecrow's Avatar
Re: could it?
awww HELL...
its the dreaded P0420...
its got a new (aftermarket) cat
oh... and what is it again???? the "thing" between the cat and the muff?
it RATTLES like CRAZY.
SO... what to do? i hear "down stream O2", fuel leak, vacuum leak. ETC.....
i do have my little pocket scan i keep in the car. I get the cel after 2 cycles.
(is it bad just to reset it and reset and reset...?) till it throws a solid code?
Old Aug 31, 2009
Scarecrow's Avatar
Re: could it?
gonna try the 2 anti plug fouler trick, see what that does.
Old Aug 31, 2009
Re: could it?
its fine to reset the code, if it keeps coming back tho theres a problem
Old Sep 6, 2009
Scarecrow's Avatar
Re: could it?
Well, it worked... i drilled out the long defouler to 1/2" and mated/mounted them.
120 miles and many cycles later, NO CODES...
IT WORKS.
only problem is that sometimes rattles against the shifter linkage, but with the heatshield rattles it already has, i'm happy with it.
