Newbie on site-first question about leak
Old Aug 11, 2009
brent1988's Avatar
brent1988 is an unknown quantity at this point
Hi Everyone,
I have recently aquired my Dad's old 1996 Honda DX. So far I've done a little basic maintenance such as plug change, air filter, rotor, and ATF change.
I just was changing a flat tire the other day and noticed a leak underneath the vehicle, just forward of the trunk/gas tank area. In fact it appears to be oil and has dripped and absorbed into an area I believe to be the front part of the gas tank.
Does anyone know what this could possibly be? I hope it is an easy fix, as I'm out of work right now. I'd sure appreciate any help or advice. Thanks!
Brent
Old Aug 11, 2009
Re: Newbie on site-first question about leak
did it leak from the engine along the exhaust pipe?
Old Aug 11, 2009
unTuned's Avatar
thats also what i was thinking. what side is the leak on? or is it in the center?
your exhaust runs down the passenger side for the most part, is it in front of the gas tank on that side? it could be water dripping from either an exhaust pipe with a hole on it, or between the exhaust pipe and the muffler. first thing i would do is try to inspect around.
looks can be deceiving. if its falling right on the floor, anything can look like oil...including water. if you find where the leak is coming from, get a clean piece of something, maybe even a plastic container and put it under so you get an idea of what exactly is leaking.
Tim1959
May 10, 2015 03:56 PM
BootyDo
May 7, 2015 04:46 PM
superstanko
Apr 28, 2015 04:38 AM
viper775
Dec 9, 2001 10:52 PM
GabberHead
Nov 20, 2001 07:32 PM
