Civic suspension upgrade?
Old Aug 6, 2009
oddjob2007's Avatar
oddjob2007 is an unknown quantity at this point
Anybody know if the Tein Coil-over kit for a 94 civic will fit on the 96 civic? Not sure what changed between the models. My friend has a setup I can get from him but would be worthless unless it can fit my 96.
Any help woud be GREAT.
Thank you
Old Aug 6, 2009
oddjob2007's Avatar
Re: Civic suspension upgrade?
This will have the Type R rear disc setup also
Old Aug 6, 2009
oddjob2007's Avatar
Wow the responses on this are amazing! does no one know if the two suspensions are the same or if they are completely different?
Old Aug 6, 2009
bluetwo's Avatar
bluetwo is an unknown quantity at this point
They will not work, not as they are anyway.
The Tein website shows the different generations as having completely different part numbers which means there are significant enough differences to necessitate different designs.
http://www.tein.com/
Old Aug 7, 2009
oddjob2007's Avatar
ok the part numbers are different but with the Type R disc brake set up will fit both a 94 and a 96 so with that swapped into the 6th Gen the rear will be the same at the 94 was setup and be able to use the Tein setup from the 94 also, right? the only diffence I then see would be the front end which I am wondering if they are the same between the 5th and 6th Gens
bsmiley
Apr 27, 2015 01:27 PM
shawe90
Apr 14, 2015 07:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
15
Nov 8, 2001 05:06 PM
SleepyT
Nov 1, 2001 04:59 AM
